Using the heap at run-time is generally discouraged as it leads to run-time failures and fragmented memory.
However, I think there is a case for dynamic allocation in init for memory that is never freed for the lifetime of the application.
E.g. collecting neighbor statistics only on the wireless interface if there is both a wireless and a wired one, or allocating a page cache on init that mirrors the size of a memory device that is only known at run-time.
Should we allow for malloc() in RIOT modules in such cases?
There was a similar discussion at some point regarding using a
one way malloc to allocate MAC descriptors 1.
I don’t see any obvious downsides of doing this and I think it could
help to clean up auto_init.
well, as you said: the use of malloc() and friends is discouraged, not
forbidden. I’m not sure the given examples would benefit from dynamic
memory allocation, but in general I would be interested to see some
investigation in this direction.
Cheers
Oleg
The best thing about declarative jokes is that you only have to prescribe
laughter, no need to actually tell the joke.
