As promissed ...
The final change to make it work was selecting the correct "mux". There
were a few hardcoded things in
* boards/samr21-xpro/include/periph_conf.h
* cpu/samd21/periph/uart.c
SAMR21_XPRO has the first serial connected to:
   RX - PA5
   TX - PA4
static const uart_conf_t uart_config = {
     /* device, RX pin, TX pin, mux */
     {&SERCOM0->USART, GPIO_PIN(PA,5), GPIO_PIN(PA,4), GPIO_MUX_D},
My SODAQ Autonomo board has the first serial connected to:
   RX - PA9
   TX - PA10
     {&SERCOM0->USART, GPIO_PIN(PA,9), GPIO_PIN(PA,10), GPIO_MUX_C},
Is that all? No, welcome to the SERCOM world of ARM Cortex M0.
In cpu/sam???/periph/uart.c some changes are needed too. In the next diff, the samr21
is the "old" samd21.
--- cpu/samd21/periph/uart.c 2016-06-13 22:41:15.358773522 +0200
+++ cpu/samr21/periph/uart.c 2016-05-31 19:57:02.788554067 +0200
@@ -86,10 +86,9 @@
      /* reset the UART device */
      dev->CTRLA.reg = SERCOM_USART_CTRLA_SWRST;
      while (dev->SYNCBUSY.reg & SERCOM_USART_SYNCBUSY_SWRST) {}
- /* set asynchronous mode w/o parity, LSB first, PAD2 to TX, PAD1 to RX, sample rate 16x and
+ /* set asynchronous mode w/o parity, LSB first, PAD0 to TX, PAD1 to RX and
       * use internal clock */
      dev->CTRLA.reg = (SERCOM_USART_CTRLA_DORD |
- SERCOM_USART_CTRLA_TXPO(0x1) |
                        SERCOM_USART_CTRLA_RXPO(0x1) |
                        SERCOM_USART_CTRLA_SAMPR(0x1) |
                        SERCOM_USART_CTRLA_MODE_USART_INT_CLK);
Notice the TXPO and RXPO. These indicate which "pads" the pin can use on a certain SERCOM.
So, what we can learn from this is that we need to expand uart_conf_t. We need PAD configuration
too. (BTW, Arduino Core is doing similar things.)
Was this a TL;DR? Sorry about it then.
-- Kees
