can someone please clean up this page: https://github.com/RIOT-OS/RIOT/wiki/Family:-ARM
The CodeBench links are dying (2 down, 1 to go).
Cheers, Ludwig
Cheers, Ludwig
seems like they want to make it a "registration ware"-software:
I'm going to remove the dead links. I'm using the tar.gz version, which is still alive. I have at least one backup of this file, if it is going to die too...
For any windows users: raise your hands now! What are you using? Do you have a copy of the windows installer on your disk?
Best Christian
Hi, I think we can use gnu arm embedded toolchain. https://launchpad.net/gcc-arm-embedded . I use it in both windows and linux . In windows, i usually use emblock ide, and it has it own bare-metal toolchain.
I added the linaro and the gnu-arm toolchains to the wiki.
We had the mentor toolchain there, because it was stable and did a good job. perhaps we go for an other "advice" in the future.
Just to be clear: one can use any toolchain that supports C99 with:
http://en.wikipedia.org/wiki/Variable-length_array
The old mentor 2008q4 toolchain is known for not supporting this feature.
Best Christian
Hi!
>I think we can use gnu arm embedded toolchain. >https://launchpad.net/gcc-arm-embedded . I use it in both windows and linux >. In windows, i usually use emblock ide, and it has it own bare-metal >toolchain.
The toolchain provided by ARM works well with the Cortex MCUs, but have shown to be problematic with ARM7 IIRC.
