Hi everyone,
PR #7457 will introduce a bootloader application.
The question came up where to put it within the source tree?
Currently the PR puts it in the root folder (./bootloader).
Do we want that? Is there a better place?
Options:
examples/bootloader
dist/tools/bootloader
gut feeling says dist/tools/bootloader
(maybe something more unique than just bootloader?), since it isn’t really part of the system and not really an example, but a quite specific application. Then again, for the same reasons I could argue to put it in the root folder, that IMHO should be kept small, however.
Martine
Hi!
I think I’m quite against dist/tools/bootloader
. Most of the code there can be built by itself, which is not the case of the bootloader… I was maybe thinking about leave it there in the root or move it to sys/ as a module. The module option seems to me a bit adequate since is an optional feature we provide to some boards, and can be deactivated when is not needed.
Paco.
Well, the boot loader is actually a full application, which is something that
has not yet been part of the RIOT source tree. So I suggest to create a new base
directory "applications" under dist/ or root (I am leaning towards dist/) for it
and put it there. That would make it either at /applications/bootloader or
/dist/applications/bootloader.
cheers
Mathias
