Hey guys,
This is a question for people using Linux to develop for RIOT-OS.
What program do you use to connect to the (USB) serial?
picocom? minicom? miniterm? grabserial? something else?
I'm looking for a program that can automatically reconnect to the
USB serial after the RIOT board does a restart. So far I only found
that minicom will do that, but not automatically.
I like the three others much better because I can more easily log
the output. However, when the board resets, it loses the connection.
> What program do you use to connect to the (USB) serial? picocom?
I sometimes use minicom, because it's generally available and can send BREAK,
but I usually wind up using screen, because then I can run it on my serial
console server, and connect to it from multiple places.
I also use rtty, but it isn't as useable because USB serial devices don't
number consistently.
> I'm looking for a program that can automatically reconnect to the USB
> serial after the RIOT board does a restart. So far I only found that
> I like the three others much better because I can more easily log the
Which board?
Are you using a board with an FTDI chip attached to a serial console?
Or one with a built-in USB? There is also the interaction with the
flashing process, which sometimes needsd the USB connection.
I'd like to convince the minicom and screen guys to do some kind of back-off
when the flasher asks.
(This is also kinda a call for dual TTY devices that showed up in SunOS
4,AIX,etc. back in the 1990s that let UUCP run well before we had mgetty.)
Which board?
It's a SODAQ board (basically an Arduino Zero compatible board) with
a SAMD21 that has onchip USB.
Well, minicom is kinda old, from the modem era. The thing I don't like
about it that it really tries to emulate a terminal. With a curses-style
popup when the tty device is gone. You can hit enter and it reconnects.
Picocom, miniterm (Python pyserial) and grabserial is what I like. I can
pipe (or tee) the output in a file.
But like I said, if my program hits a watchdog reset, it reboots, and my
USB connection is gone. In my startup I want to print the reset cause
to know what was going on.
In the past I was using one of the UARTs of the SAMD21. In a sense that
was much easier.
I hate to say it, but it seems on Windows there is a solution (they tell
me).
That, by itself, bothers me too
Which board? Are you using a board with an FTDI chip attached to a
>> serial console? Or one with a built-in USB?
> It's a SODAQ board (basically an Arduino Zero compatible board) with a
So you lose your USB device each time it reboots.
>> There is also the interaction with the flashing process, which
>> sometimes needsd the USB connection. I'd like to convince the minicom
>> and screen guys to do some kind of back-off when the flasher asks.
>> SunOS 4,AIX,etc. back in the 1990s that let UUCP run well before we
>> had mgetty.)
> curses-style popup when the tty device is gone. You can hit enter and
> it reconnects.
Yes, it reconnects. The rest don't.
Either fix the rest to reconnect ...
Getting the USB to enumerate consistently is what bugs me.
It requires a unique ID in the USB, which most of the devices haven't
bothered to provision
> my USB connection is gone. In my startup I want to print the reset
> cause to know what was going on.
Sounds like ten lines of python.
> tell me). That, by itself, bothers me too
Windows GUI programs mostly can't pipe stuff.
The ones that can, are usually just using the Linux ABI now.
pyterm [1] will do that. It's the default when you run
make term
in RIOT's build system.
It will output to the console and keep logs in ~/.pyterm, so it's
pretty handy.
[1] https://github.com/RIOT-OS/RIOT/tree/master/dist/tools/pyterm
Wow, I never knew it was there. Great. It even has timing. Impressive.
Minor twit. It's missing the first 45 characters or so.
2020-05-18 20:41:02,547 # Connect to serial port /dev/ttyACM0
Welcome to pyterm!
Type '/exit' to exit.
2020-05-18 20:41:03,550 # -602-g39227-add-sodaq-sff)
2020-05-18 20:41:03,551 # Hello World!
2020-05-18 20:41:03,552 # You are running RIOT on a(n) sodaq-sara-sff board.
2020-05-18 20:41:03,553 # This board features a(n) samd21 MCU.
2020-05-18 20:46:06,269 # Serial port disconnected, waiting to get
reconnected...
2020-05-18 20:46:07,276 # Serial port disconnected, waiting to get
reconnected...
2020-05-18 20:46:08,277 # Try to reconnect to /dev/ttyACM0 again...
2020-05-18 20:46:08,278 # Reconnected to serial port /dev/ttyACM0
2020-05-18 20:46:08,279 # -602-g39227-add-sodaq-sff)
2020-05-18 20:46:08,280 # Hello World!
2020-05-18 20:46:08,281 # You are running RIOT on a(n) sodaq-sara-sff board.
2020-05-18 20:46:08,281 # This board features a(n) samd21 MCU.
Even so, I'm quite happy.
