Hi *,
some of you may knows that there several problems in the vtimer at the moment. I would like to ask you to report issues you have spotted and also comment my suggested changes.
Issues I know: * long_term is everytime 4096 seconds, regardless if the hwtimer is able to measure this amount of time * seconds are only updated on long_term (each 4096 seconds) * vtimer is not tickless (through long_term) * When setting two timers very close to each other the second is sometimes never called * shortterm_queue_root.next is not set in every case update_shortterm is called * The maximum value of a timex_t can exceed the maximum measurement of the vtimer (now + MAX(timex_t) > MAX(timex_t) for each now > 0)
I would prefer to not use long_term updates at the behavior it is used now. I would suggest to only use a long_term update before the hwtimer overflows. I also would like to update seconds every time a set or now or callback function is called. When calling update_shorttime all timers should be triggered that are in the past + the amount needed to set the timer. If a timer is set with a value greater than the value the vtimer can handle vtimer_set should only return -1 and do nothing.
Please let me know what you think and what kind of issues you had with the vtimer.
Regards, Milan
