valgrind support in native
I just opened a pull request for valgrind support in native: https://github.com/RIOT-OS/RIOT/pull/230
This PR makes native depend on valgrind which I guess is reasonable as valgrind should be used anyways. If you think it should rather be opt-out or even opt-in let me know and I'll ifdef around it.
Cheers, Ludwig
Nice!
I'd definitely be for opt-in. We don't have any autoconf yet, so users will definately stumble over "cannot find valgrind.h"....
Keep dependencies to a minimum.
Why do you think "valgrind should be used anyways"?
Cheers, Kaspar
OK, I'll update the PR accordingly.
Keep dependencies to a minimum. Why do you think "valgrind should be used anyways"?
Not using valgrind is like disabling compiler warnings, only worse :wink: For me valgrind is about as much a dependency as a compiler is...
Cheers, Ludwig
I just did.
Cheers, Ludwig
