Hey, is anyone (besides @chrysn ) looking into using Rust? I gave myself a new challenge. I want to learn Rust. And to start off with a real challenge I want to learn Rust in an embedded environment, with RIOT-OS.
@chrysn created riot-examples [1] which is, I think, a good starting point. However, not everything is working for me. It works for BOARD=stm32l476g-disco but not for my SODAQ boards such as BOARD=sodaq-sara-sff. Both use the same toolchain, but for any cortexm board the build fails with that it cannot find stdio.h. I tried to understand what is happening (cargo build is a beast), used strace and more. Still I have no clue what is going on and why it fails to find stdio.h in one case but not in the other.
Thus my question: who else has tried this?
[1] etonomy / riot-examples · GitLab
@Kaspar is also looking into Rust + RIOT, maybe he would have an idea as well?
18 January 2021 08:56
3
keestux:
Can’t help you with that one because of a different issue .
keestux:
This I can only recommend, Rust is awesome.
I’ve started experimenting with core written in Rust which can be used together with RIOT. The thing also makes use of @chrysn ’s riot-wrappers. It is very experimental, but initial code is here . But so far it only supports the nrf52840dk.
@Kaspar can you try to just build saul_blink for some samd21 board. I want confirmation that it is not my own installation at fault.
18 January 2021 16:17
5
I’m getting the same stdio.h error:
/home/kaspar/src/riot.tmp/cpu/cortexm_common/include/cpu.h:33:10: fatal error: 'stdio.h' file not found, err: true
thread 'main' panicked at 'Unable to generate bindings: ()', /home/kaspar/.cargo/registry/src/github.com-1ecc6299db9ec823/riot-sys-0.3.1/build.rs
This worked before, no idea what has changed.
Thanks
Let’s hope @chrysn will chime in someday
My suspicion is that clang is called in the build process and that it is using the wrong set of include directories. I believe clang is used to preprocess some files, but in doing so, it should never fall back to the “system” (i.e. host version) include directories. And with strace I could see that it is doing just that.
Plus, it remains a mystery that two arm-none-eabi boards can give different result. One builds, the other one doesn’t.
Does someone know if etonomy is still active with https://gitlab.com/etonomy/riot-examples i got a PR open there for some time
2 February 2021 15:57
8
AFAIK etonomy is using the underlying riot-wrappers for their product. I guess the examples don’t get as much attention because @chrysn is busy.
chrysn
5 February 2021 14:47
9
Sorry, missed the notification, I’ll get back to it.
@chrysn Do you have an idea why the examples don’t build for samd21 boards? (See my initial message in this thread.)
chrysn
13 February 2021 15:45
11
Mh, I can reproduce it (based on 2021.01 RIOT and latest HEAD (96fbfd46) of the examples); looking into it.
chrysn
13 February 2021 19:29
12
What I got so far:
It seems to be CPU core specific; I’ve only seen this on cortex-m0 and
cortex-m0plus boards, which are both armv6s-m (like stk3200 or
nucleo-f072rb even though they hit stdint.h first; not m3 as in
stk3700).
When using TOOLCHAIN=llvm, the trouble goes away (except for stk3200
but it’s a ROM overflow that kills it there – haven’t tried to optimize
anything there yet, but Rust’s standard string formatting is pretty
heavy).
I think I should make LLVM the recommendation for Rust-on-RIOT anyway.
Still looking for what actually causes this, but at least using LLVM
should get you going again.
The whole process is quiet complicated. I got lost in all the details. Somehow I got the impression that one of the (underlying) compilation/preprocessing was done with the host environment instead of the cross-compile environment.
Doing an strace I could see /usr/include/stdio.h being used and that can never be correct for a non-native board. But like I said, it’s complicated, I could be totally wrong.
And there may even be a RIOT problem with detection the correct details of the toolchain (especially include directories).
chrysn
13 February 2021 20:24
14
But do you get your applications to work with TOOLCHAIN=llvm at least?
(Honestly, it may be that GCC is something supporting which I’d
postpone.)
The over-all situation is admittedly far from ideal. Trouble is that
neither bindgen nor c2rust are particularly cross-building friendly
(even tough Rust itself usually is). Maybe I’m also doing it wrong, and
should (rather than trying to find the right build arguments
half-on-my-own) ask the RIOT build system for the right build arguments
for LLVM, apply those and trust the implied promise that no matter the
toolchain, the C ABI is upheld and they can link interchangably.
Knowing whether the problem dissolves for you too with TOOLCHAIN=llvm
would be one data point to guide that decision. (If I go the
abovementioned route in the default build integrations, the GCC could
then become usable again).
I can confirm that the saul_blink example works with TOOLCHAIN=llvm
chrysn
13 February 2021 21:18
16
Having dug farther and farther into which CFLAGS are set why and when, I
think more and more that the right way for riot-sys (or, more, the build
integration) is to ask the RIOT build system for which CFLAGS would be
set if building with CLANG.
Unfortunately, these are not set just in the toolchain specific
includes, but at several places by checking for TOOLCHAIN. That should
also solve the issues about the host stdio.h being used, because when
clang is used, the makefiles pass the rigth libc to use in CFLAGS
(eg. libc/newlib.mk in NEWLIB_INCLUDES).
(Really, that the libc is entangled with the compiler in the first place
is a mess of its own).
The easy step is to update the examples (done), the next step is
properly resolving #3 .
15 February 2021 10:01
17
chrysn:
Maybe I’m also doing it wrong, and should (rather than trying to find the right build arguments half-on-my-own) ask the RIOT build system for the right build arguments for LLVM, apply those and trust the implied promise that no matter the toolchain, the C ABI is upheld and they can link interchangably.
That’s what I’m doing with RIOT-rs, just use the output of “make info-debug-variable-CFLAGS” etc.
Great to see that Rust on RIOT still is moving forward. Keep up the good work.
Hi, I’m having trouble running make on examples/rust-hello-world.
command: make RUST_BACKTRACE=full BOARD=native all term
toolchain: nightly, due to error[E0554]: #![feature] may not be used on the stable release channel.
OS: linux debian 10
Full log output of `make`
Building application "hello-world" for "native" with MCU "native".
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/boards/native compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/boards/native/drivers compile-commands
make[3]: Nothing to be done for 'compile-commands'.
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/core compile-commands
make[2]: Nothing to be done for 'compile-commands'.
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native/periph compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native/stdio_native compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers/periph_common compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/sys compile-commands
"make" -C /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/sys/auto_init compile-commands
Compiling riot-sys v0.5.2
error: failed to run custom build command for `riot-sys v0.5.2`
Caused by:
process didn't exit successfully: `/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/examples/rust-hello-world/bin/native/target/release/build/riot-sys-947eab958480932d/build-script-build` (exit status: 101)
--- stdout
cargo:rerun-if-env-changed=RIOT_COMPILE_COMMANDS_JSON
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/examples/rust-hello-world/bin/native/cargo-compile-commands.json
cargo:rerun-if-env-changed=RIOT_USEMODULE
cargo:rerun-if-env-changed=RIOT_CC
cargo:rerun-if-env-changed=RIOT_CFLAGS
cargo:CC=clang
cargo:CFLAGS="-DRIOT_FILE_RELATIVE=\"/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native/async_read.c\"" "-DRIOT_FILE_NOPATH=\"async_read.c\"" -DDEVELHELP -Werror -Wall -Wextra -pedantic -g3 -Og -U_FORTIFY_SOURCE "-std=gnu11" -m32 -fstack-protector-all -ffunction-sections -fdata-sections -DDEBUG_ASSERT_VERBOSE "-DRIOT_APPLICATION=\"hello-world\"" "-DBOARD_NATIVE=\"native\"" "-DRIOT_BOARD=BOARD_NATIVE" "-DCPU_NATIVE=\"native\"" "-DRIOT_CPU=CPU_NATIVE" "-DMCU_NATIVE=\"native\"" "-DRIOT_MCU=MCU_NATIVE" -fwrapv -Wstrict-overflow -fno-common -ffunction-sections -fdata-sections -Wall -Wextra -Wmissing-include-dirs -fno-delete-null-pointer-checks -fdiagnostics-color -Wstrict-prototypes -Wold-style-definition -gz "-Wformat=2" -Wcast-align -include /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/examples/rust-hello-world/bin/native/riotbuild/riotbuild.h -DNATIVE_INCLUDES -I/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/boards/native/include/ -I/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/core/include/ -I/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers/include/ -I/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native/include -I/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/sys/include -MQ async_read.o -MD -MP -DMODULE_AUTO_INIT -DMODULE_BOARD -DMODULE_CORE -DMODULE_CORE_IDLE_THREAD -DMODULE_CORE_INIT -DMODULE_CORE_MSG -DMODULE_CORE_PANIC -DMODULE_CPU -DMODULE_NATIVE_DRIVERS -DMODULE_PERIPH -DMODULE_PERIPH_COMMON -DMODULE_PERIPH_GPIO -DMODULE_PERIPH_GPIO_LINUX -DMODULE_PERIPH_INIT -DMODULE_PERIPH_INIT_GPIO -DMODULE_PERIPH_INIT_GPIO_LINUX -DMODULE_PERIPH_INIT_PM -DMODULE_PERIPH_INIT_UART -DMODULE_PERIPH_PM -DMODULE_PERIPH_UART -DMODULE_STDIO_NATIVE -DMODULE_SYS -DMODULE_
cargo:rerun-if-changed=riot-bindgen.h
cargo:rerun-if-changed=/usr/include/fcntl.h
cargo:rerun-if-changed=/usr/include/features.h
cargo:rerun-if-changed=/usr/include/stdc-predef.h
cargo:rerun-if-changed=/usr/include/sys/cdefs.h
cargo:rerun-if-changed=/usr/include/bits/wordsize.h
cargo:rerun-if-changed=/usr/include/bits/long-double.h
cargo:rerun-if-changed=/usr/include/gnu/stubs.h
cargo:rerun-if-changed=/usr/include/gnu/stubs-32.h
cargo:rerun-if-changed=/usr/include/bits/types.h
cargo:rerun-if-changed=/usr/include/bits/typesizes.h
cargo:rerun-if-changed=/usr/include/bits/fcntl.h
cargo:rerun-if-changed=/usr/include/bits/fcntl-linux.h
cargo:rerun-if-changed=/usr/include/bits/types/struct_timespec.h
cargo:rerun-if-changed=/usr/include/bits/stat.h
(... truncated ...)
cargo:rerun-if-changed=/usr/include/errno.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/sys/include/phydat.h
cargo:rerun-if-changed=/usr/lib/llvm-7/lib/clang/7.0.1/include/stddef.h
cargo:rerun-if-changed=/usr/lib/llvm-7/lib/clang/7.0.1/include/stdint.h
cargo:rerun-if-changed=/usr/include/stdint.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/core/include/kernel_defines.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/sys/include/saul_reg.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers/include/saul.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/boards/native/include/board.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers/include/motor_driver.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers/include/periph/pwm.h
cargo:rerun-if-changed=/usr/lib/llvm-7/lib/clang/7.0.1/include/limits.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native/include/periph_cpu.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/cpu/native/include/periph_conf.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/drivers/include/periph/gpio.h
cargo:rerun-if-changed=/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/core/include/mutex.h
cargo:rerun-if-changed=riot-c2rust.h
Running C2Rust on /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/examples/rust-hello-world/bin/native/target/i686-unknown-linux-gnu/release/build/riot-sys-0ecdd0d8caa105c6/out/compile_commands.json
--- stderr
thread 'main' panicked at 'C2Rust failed: Os { code: 2, kind: NotFound, message: "No such file or directory" }', /home/geovane/.cargo/registry/src/github.com-1ecc6299db9ec823/riot-sys-0.5.2/build.rs:259:10
stack backtrace:
0: 0x55930ee0677c - std::backtrace_rs::backtrace::libunwind::trace::h8be286d067839d4f
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/../../backtrace/src/backtrace/libunwind.rs:93:5
1: 0x55930ee0677c - std::backtrace_rs::backtrace::trace_unsynchronized::h44b722b66416ac08
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
2: 0x55930ee0677c - std::sys_common::backtrace::_print_fmt::h2b78b2a0da201765
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/sys_common/backtrace.rs:67:5
3: 0x55930ee0677c - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::h890804b6cfffe9fc
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/sys_common/backtrace.rs:46:22
4: 0x55930ee2bf2c - core::fmt::write::h0200d27bf417ad61
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/core/src/fmt/mod.rs:1149:17
5: 0x55930ee02455 - std::io::Write::write_fmt::h917ab11fd974bb56
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/io/mod.rs:1660:15
6: 0x55930ee08210 - std::sys_common::backtrace::_print::hc83d16fbacc2fa85
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/sys_common/backtrace.rs:49:5
7: 0x55930ee08210 - std::sys_common::backtrace::print::hf2dccf30793e7b28
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/sys_common/backtrace.rs:36:9
8: 0x55930ee08210 - std::panicking::default_hook::{{closure}}::h8710dbf03f1859af
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:211:50
9: 0x55930ee07dc9 - std::panicking::default_hook::h86966dcda268d57f
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:228:9
10: 0x55930ee08846 - std::panicking::rust_panic_with_hook::h7a6b21c56a75680a
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:606:17
11: 0x55930ee083a0 - std::panicking::begin_panic_handler::{{closure}}::h0b5fbdfb333891b7
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:502:13
12: 0x55930ee06c14 - std::sys_common::backtrace::__rust_end_short_backtrace::h00f7bbe7bd683fd2
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/sys_common/backtrace.rs:139:18
13: 0x55930ee08309 - rust_begin_unwind
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:498:5
14: 0x55930e8f3b51 - core::panicking::panic_fmt::h8bc989e1fc10c635
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/core/src/panicking.rs:107:14
15: 0x55930e8f3c43 - core::result::unwrap_failed::hddb26cddfa4f23d4
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/core/src/result.rs:1661:5
16: 0x55930e908111 - core::result::Result<T,E>::expect::h7c6cb85fa04698aa
17: 0x55930e90b98f - build_script_build::main::h0f22d1b7414bfb57
18: 0x55930e914173 - core::ops::function::FnOnce::call_once::hcb005b2721bc47ff
19: 0x55930e8fe289 - std::sys_common::backtrace::__rust_begin_short_backtrace::hf2fa7b8054e63c44
20: 0x55930e9164e9 - std::rt::lang_start::{{closure}}::h650f35655fd2908a
21: 0x55930ee05f7e - core::ops::function::impls::<impl core::ops::function::FnOnce<A> for &F>::call_once::hf229fdbad64016f2
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/core/src/ops/function.rs:259:13
22: 0x55930ee05f7e - std::panicking::try::do_call::h7d8598f65f6219c4
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:406:40
23: 0x55930ee05f7e - std::panicking::try::h91692f755b878b6e
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panicking.rs:370:19
24: 0x55930ee05f7e - std::panic::catch_unwind::h5667558f93dc5a36
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/panic.rs:133:14
25: 0x55930ee05f7e - std::rt::lang_start_internal::{{closure}}::h744d08babf4d6cde
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/rt.rs:128:48
26: 0x55930ee05f7e - std::panicking::try::do_call::h42aa3ce4fdbcbb52
27: 0x55930ee05f7e - std::panicking::try::hcafbaff38524399c
28: 0x55930ee05f7e - std::panic::catch_unwind::h1f614557dce738da
29: 0x55930ee05f7e - std::rt::lang_start_internal::h75965f95c98f11d8
at /rustc/34926f0a1681458588a2d4240c0715ef9eff7d35/library/std/src/rt.rs:128:20
30: 0x55930e9164d1 - std::rt::lang_start::h4f98c55f05635953
31: 0x55930e90d7d3 - main
32: 0x7f68bf27109b - __libc_start_main
at /build/glibc-vjB4T1/glibc-2.28/csu/../csu/libc-start.c:308:16
33: 0x55930e8f42ea - _start
34: 0x0 - <unknown>
make: *** [/home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/makefiles/cargo-targets.inc.mk:20: /home/geovane/dev/swarm/dev/tmp/explore-riot/RIOT-geo/examples/rust-hello-world/bin/native/target/i686-unknown-linux-gnu/release/librust_hello_world.a] Error 101
The main error seems to be error: failed to run custom build command for riot-sys v0.5.2.
Any ideas?
mcr
23 December 2021 22:32
20
I didn’t notice that rust-hello-world needs nightly. I’d like to fix that.
Looking at the details, which I saw by email, and I have no idea how to show online, I think that the issue is:
I think that this is rust macros that are being used at runtime, but I admit that I don’t know how this is goign together. Yoichi and I created a different way to integrate Rust and RIOT-OS. It was in our RIOT-OS talk, if your goal is just to get the job done, rather than to integrate this way.
