Hy!
I'd like to update the micro-ecc package included with RIOT-OS, since the
current version is pretty outdated.
Currently, the package uses a patch which removes all the random number
generation code from micro-ecc and substitutes it for invocation to the hwrng
interface.
Wouldn't it be more straight-forward, to just plug the hwrng intefrface into
micro-ecc directly (via the uECC_set_rng function), instead of making big
alterations?
cheers
Mathias
Hey Mathias,
Hy!
interface.
alterations?
To me that sounds like a really good solution. I don't know anything
about the internals of the micro-ecc package but from a maintenance
burden perspective it is usually better to have as small and as few
changes from upstream as possible. Would you be willing to provide a
PR?
If you provide a PR, check that the micro-ecc RNG code does not bloat
the binary by still being linked in for providing some fallback
mechanism. (Like I said, I don't know anything about micro-ecc
internals so I don't know if this is the case)
Joakim
At the moment, I am working only on the basic update which can be used in the
same way as the current version in RIOT.
I have a few issues to clarify with the micro-ecc folks, but the pull request
should be ready in the next days.
cheers
Mathias
