My name is Vishal Rathod and I am a research scholar at NITK, India. I am working on congestion control and NDN in Internet of Things.
For NDN, I found that RIOT is very useful to do some experimentation. I want to create a topology like four machines (e.g. Raspberry Pi) with RIOT OS and Interconnected. I want to communicate to the four machines through my Desktop / Laptop machine.
I thought, there are two ways to install RIOT:
clone the GitHub repository and compile the OS.
To install RIOT as an operating system like ubuntu.
My doubt is, how can I install RIOT on raspberry pi as an operating system? Or any other idea to install it as an OS?
You can't easily run RIOT-OS on an RPI as the operating system.
You can compile it for Linux native and run it under ubuntu, then connect (bridge) it
to physical interface, etc. but that's probably not going to give you results
you are looking for.
You can’t easily run RIOT-OS on an RPI as the operating system.
So, does it means that I can run RIOT-OS on RPI with some modification?
to physical interface, etc. but that’s probably not going to give you results
Can you guide me which way I can create the same topology using RIOT?
Hi Ratod,
I agree with Emmanuel here, maybe you should consider not using
Raspberry PIs, but microcontrollers. Why do you want to use PIs in the
first place?
- Robert
