I am trying to set address and channel for the transceiver CC2420. I am able to set the address on both the transmitter and the receiver but I am not able to set the channel on either.
I traced the SET_CHANNEL function call all the way up to the cc2420 module and it returns me the channel set as the value that I pass all the way through but when I try to confirm it by typing “chan”(which is predefined shell command to get the channel of the transceiver), it gives me a value of ~ 1861.
Please help!
Hi Shivani!
through but when I try to confirm it by typing "chan"(which is predefined
of ~ 1861.
I can confirm this issue on the Zolertia Z1. Can you please open an issue on
Github describing the problem?
Oleg
Hi Shivani again,
I found the problem and opened a PR:
https://github.com/RIOT-OS/RIOT/pull/3503
Oleg
Oleg,
Thanks a lot for the fix. I am able to set the channel now.
