I am trying to compile RIOT on a new ubuntu 22.04 and I get some weird errors. Any help would be appreciated.
make all -C examples/default/
make: Entering directory '/home/ichatz/Local/RIOT/examples/default'
Building application "default" for "native" with MCU "native".
"make" -C /home/ichatz/Local/RIOT/boards/common/init
"make" -C /home/ichatz/Local/RIOT/boards/native
"make" -C /home/ichatz/Local/RIOT/boards/native/drivers
"make" -C /home/ichatz/Local/RIOT/core
/home/ichatz/Local/RIOT/core/assert.c:21:9: error: expected ‘;’ before ‘void’
21 | NORETURN void _assert_failure(const char *file, unsigned line)
/home/ichatz/Local/RIOT/core/assert.c: In function ‘_assert_failure’:
/home/ichatz/Local/RIOT/core/assert.c:24:5: error: implicit declaration of function ‘core_panic’ [-Werror=implicit-function-declaration]
24 | core_panic(PANIC_ASSERT_FAIL, assert_crash_message); \
/home/ichatz/Local/RIOT/core/assert.c:24:16: error: ‘PANIC_ASSERT_FAIL’ undeclared (first use in this function)
/home/ichatz/Local/RIOT/core/assert.c:24:16: note: each undeclared identifier is reported only once for each function it appears in
/home/ichatz/Local/RIOT/core/assert.c:24:35: error: ‘assert_crash_message’ undeclared (first use in this function)
/home/ichatz/Local/RIOT/core/assert.c:25:1: error: ‘noreturn’ function does return [-Werror]
25 | }
cc1: all warnings being treated as errors
make[2]: *** [/home/ichatz/Local/RIOT/Makefile.base:146: /home/ichatz/Local/RIOT/examples/default/bin/native/core/assert.o] Error 1
make[1]: *** [/home/ichatz/Local/RIOT/Makefile.base:31: ALL--/home/ichatz/Local/RIOT/core] Error 2
make: *** [/home/ichatz/Local/RIOT/examples/default/../../Makefile.include:749: application_default.module] Error 2
make: Leaving directory '/home/ichatz/Local/RIOT/examples/default'
Here are some info on my system:
make print-versions
Operating System Environment
Operating System: "Ubuntu" "22.04.1 LTS (Jammy Jellyfish)"
Kernel: Linux 5.15.0-58-generic x86_64 x86_64
System shell: /usr/bin/dash (probably dash)
make's shell: /usr/bin/dash (probably dash)
Installed compiler toolchains
native gcc: gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0
arm-none-eabi-gcc: arm-none-eabi-gcc (15:10.3-2021.07-4) 10.3.1 20210621 (release)
avr-gcc: missing
msp430-elf-gcc: missing
riscv-none-elf-gcc: missing
riscv64-unknown-elf-gcc: missing
riscv-none-embed-gcc: missing
xtensa-esp32-elf-gcc: xtensa-esp32-elf-gcc (crosstool-NG esp-2022r1) 11.2.0
xtensa-esp8266-elf-gcc: missing
clang: missing
Installed compiler libs
arm-none-eabi-newlib: "3.3.0"
msp430-elf-newlib: missing
riscv-none-elf-newlib: missing
riscv64-unknown-elf-newlib: missing
riscv-none-embed-newlib: missing
xtensa-esp32-elf-newlib: "4.1.0"
xtensa-esp8266-elf-newlib: missing
avr-libc: missing (missing)
Installed development tools
ccache: ccache version 4.5.1
cmake: cmake version 3.22.1
cppcheck: missing
doxygen: 1.9.1
git: git version 2.34.1
make: GNU Make 4.3
openocd: Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:47)
python: Python 3.10.6
python2: missing
python3: Python 3.10.6
flake8: error: /home/ichatz/.espressif/python_env/idf5.1_py3.10_env/bin/python3: No module named flake8
coccinelle: missing
