Hi everyone, Sorry to disturb y'all. This is my second post here, still not able to build the native code
This is the output that am getting. "make" -C /home/riot/RIOT/sys/shell "make" -C /home/riot/RIOT/sys/shell/commands /usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.9/libgcc.a when searching for -lgcc /usr/bin/ld: cannot find -lgcc /usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.9/libgcc_s.so when searching for -lgcc_s /usr/bin/ld: cannot find -lgcc_s collect2: error: ld returned 1 exit status make: *** [all] Error 1
It would be great if you could provide some insight.
Thanks, tbyy
gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.9/lto-wrapper Target: x86_64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.9.3-8ubuntu2~14.04' --with-bugurl=file:///usr/share/doc/gcc-4.9/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.9 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.9 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.9-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.9-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.9-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu Thread model: posix gcc version 4.9.3 (Ubuntu 4.9.3-8ubuntu2~14.04)
