Hello everyone,
this week I made some success with exploring RIOT OS.
But now I stuck with trying to get a data transfer between a 6LoWPAN equiped Raspberry Pi and "RIOT-MCUs".
All my tests are based on the gnrc_networking example.
First I made a UDP transfer between 2 identical RIOT equiped MCU boards. On the first device I started
a UDP server and from the other I generated some data trafic to the other. Result: full success - I have seen
the traffic on the shell (pktdump) and it was O.K.
Then I set up a Raspberry for usage with 6LoWPAN as described on the RIOT web page.
ping6 works wonderful in each direction but when I tried to get data trafic through UDP I got
nothing - neither in one direction nor in the other.
I tried also to listen to the UDP port with netcat6 - also no success.
Can anyone give me a hint what's different between a UDP transfer between 2 RIOT devices and a trafic
between a Linux-based UDP server and a RIOT-based device? The "basic"-Interface seems O.K. because
of the working ping6.
Linux uses next header compression (NHC) for UDP communication. Sadly,
our implementation of NHC has still some issues when forwarding
packets [1, 2, 3], which are about to be fixed in the next few days or
so. This is why we currently have it deactivated by default. For now,
if you don't use a RIOT node as multihop router (your scenario does
not sound like it) you can activate NHC manually by adding the module
`gnrc_sixlowpan_nhc_iphc` to your USEMODULE list.
seems like we are following the same route:) for the moment I can only confirm that riot 6lowpan “host” works with rpi2 and mainline kernel “node” implementation.
(Linux raspberrypi 4.1.13-v7+)
Recently I got working coap server on riot side with coap client on rpi2 side. The only thing I had to do on linux side was to remove nhc_udp module.
Dont you have some kind of sniffer, to check what is in the air?
Im not using default build system, but here are my --defines for the reference:
