I’ve recently picked up an interest in LoRa and LoRaWAN, and have started experimenting with it a few weeks ago. Unfortunately, I’ve not have had much success so far…
I’ve been hesitant to open a new topic since there were already two other Lorawan topics active and maybe the answer to my problems would also pop up there, but unfortunately I think that is not the case. So another topic it is!
What hardware am I using?
I bought one Dragino Raspberry Pi hat running on an RPi2 and use it as a gateway to TheThingsNetwork.
I also bought a couple of devices that I intended to use as a node. One of them is this esp32 lorawan stick. If I’m not mistaken, this one is supported by RIOT under the name “esp32-heltec-lora32-v2”.
What works?
I installed the dual_chan_pkt_fwd software according to the Dragoni install guide. When I fill in the correct credentials it shows up on my TTN dashboard as “connected”. I flashed examples/lorawan on the heltec board (of course, again with the correct credentials). When I reset the board, I can see traffic in the dump of the gateway. Thus, the node is able to connect to the gateway. The TTN dashboard also confirms this: when I check the Traffic tab it shows two incoming Join requests (not sure why there’s two?) and a Join Accept message. So… the node is able to reach TTN through my gateway without any problems, and TTN also accepts its request to join the network. The Device page also confirms this: it shows one Activation package, and shows “Connected” as the device status. (Or something along the lines of “last seen: 10 seconds ago”) (See screenshots below)
Then what’s the problem?
Well… This is where the good news ends. Even though TTN reports a successful join, RIOT reports a failure:
2021-02-08 22:00:49,293 # rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
2021-02-08 22:00:49,295 # configsip: 0, SPIWP:0xee
2021-02-08 22:00:49,301 # clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
2021-02-08 22:00:49,303 # mode:DOUT, clock div:2
2021-02-08 22:00:49,305 # load:0x3fff0018,len:4
2021-02-08 22:00:49,308 # load:0x3fff001c,len:4004
2021-02-08 22:00:49,310 # load:0x40078000,len:7304
2021-02-08 22:00:49,312 # load:0x40080000,len:7224
2021-02-08 22:00:49,314 # entry 0x40080350
2021-02-08 22:00:50,026 # RTC: Not found External 32 kHz XTAL. Switching to Internal 150 kHz RC chain
2021-02-08 22:00:50,078 # [rtt] 32.768 kHz crystal not used!
2021-02-08 22:00:50,081 # [rtt] 32.768 kHz crystal not used!
2021-02-08 22:00:50,086 # main(): This is RIOT! (Version: 2021.04-devel-229-g83201)
2021-02-08 22:00:50,089 # LoRaWAN Class A low-power application
2021-02-08 22:00:50,092 # =====================================
2021-02-08 22:00:50,096 # [semtech-loramac] initializing loramac
2021-02-08 22:00:50,152 # Starting join procedure
2021-02-08 22:00:50,156 # [semtech-loramac] Starting join procedure: 0
2021-02-08 22:00:50,158 # [semtech-loramac] loramac cmd msg
2021-02-08 22:00:50,162 # [semtech-loramac] starting OTAA join
2021-02-08 22:00:50,258 # [semtech-loramac] Transmission completed
2021-02-08 22:00:51,193 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:52,194 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:53,194 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:54,194 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:55,194 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:55,203 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:56,062 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:56,195 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:57,195 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:58,195 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:58,206 # [semtech-loramac] RX timer timeout
2021-02-08 22:00:59,195 # [semtech-loramac] MAC timer timeout
2021-02-08 22:00:59,198 # [semtech-loramac] MLME confirm event
2021-02-08 22:00:59,202 # [semtech-loramac] MLME confirm msg received
2021-02-08 22:00:59,205 # [semtech-loramac] join not successful
2021-02-08 22:00:59,207 # Join procedure failed
I’ve been trying to find the cause, but have thus far failed to do so…
Some screenshots of the TTN-dashboard:
Anyone have an idea what might be going wrong and how I can get it to work?
