I tried to flash the default application into a telosb board. As you can see, the below errors seems to be bugs. Have anyone else faced these issues?
/home/rikhu/RIOT/dist/tools/pyterm/pyterm -p “/dev/ttyUSB0” -b “115200” 2016-01-13 11:20:18,167 - INFO # Connect to serial port /dev/ttyUSB0 Welcome to pyterm! Type ‘/exit’ to exit. help 2016-01-13 11:20:22,082 - INFO # �F�"�nn�~���v�ճ�d33�NenWD�΄D�#�o�~�dz��D5hl 2016-01-13 11:20:22,179 - INFO # shell: command not found: hl help 2016-01-13 11:20:35,312 - INFO # > hl 2016-01-13 11:20:35,315 - INFO # shell: command not found: hl ifconfig 2016-01-13 11:20:39,670 - INFO # > icnfig 2016-01-13 11:20:39,673 - INFO # shell: command not found: icnfig
Rik
