Hello there,
I have set up a TCP-server and -client to test with “tcp header compression “. However I’m not able to set up a connection from the client to the server with the function „tcp_connect“ (I‘m using the native board). I used the general approach - generate socket, set address information, use function „tcp_connect“, ……
In wireshark I saw that the client did not send any data out to the tap-interface. Can somebody give me a hint regarding the use of tcp-sockets in riot with native boards? Are there exist any tcp-server/client applications?
Tom
