Subject: Re: devel Digest, Vol 41, Issue 7
Hi Martin, Currently i'm using a SAMR21-XPRO because OpenMote doesn't provide tranceiver's drivers. Anyway this issue is strange...
Alessandro
Hi Alessandro,
Hi Martin,
My name's Martine :wink:
Sorry... I meant the OpenLabs radio adapter for the Raspberry Pi [1]. OpenMote, OpenLabs... either to confuse ^^"
Currently there are two (predominant) ways to set-up a border router between RIOT and the Internet via Linux: either use a Raspberry Pi with an OpenLabs-type device mounted on it using this [2] tutorial, or by flashing the gnrc_border_router example to another node [3]. Which one did you went for? If you went for the first: please try the second (if you have another radio-equipped device).
Hope my reply could provide some clearance.
Subject: Re: [riot-devel] devel Digest, Vol 41, Issue 7
Also could you maybe change your subscriber settings to non-digest subscription or at least keep the discussion context, please? I know that this causes more mails in your Inbox, but with some clever filtering this shouldn't be a problem. On the other hand, the digest format makes following our discussion very hard, since it shreds the thread structure (see [4]). I'm not even 100% sure what you are talking about in your reply.
Cheers, Martine
[1] http://openlabs.co/store/Raspberry-Pi-802.15.4-radio [2] https://github.com/RIOT-OS/RIOT/wiki/How-to-install-6LoWPAN-Linux-Kernel-on-Raspberry-Pi#raspberrypi-with-openlabs-raspberry-pi-802154-radio [3] https://github.com/RIOT-OS/RIOT/tree/master/examples/gnrc_border_router [4] https://lists.riot-os.org/pipermail/devel/2016-July/thread.html
