Hello, I am currently trying the srf04 test and i constantly have the same error “Error initializing”.I did some digging but i can’t find any solution to this problem.I am using an arduino-uno for this task. Thank you in advance!
Hey,
this error comes from the initialisation of the gpio pins [0].
You can find that the default params of the srf04 [1] pins are set to GPIO_PIN(0,13) and GPIO_PIN(0,14). Those are kind of logical pins - NOT pins 13 and 14 on your hardware - and it seems RIOT does not provide these logical pins on the arduino-atmega boards as given in the boards config [2] (these are definitions for a family of arduino boards, one of them is the uno).
You will have to set up your own params, to change the GPIO Pins to some available pins from [2].
best Semjon
[0]
[1] [2]
