I'm trying to get the mrf24j40 radio working with the stm32f0discovery, I've connected it correctly (to my understanding), but SPI seems to fail to initialize.
Currently the following code is used to test, with ENABLE_DEBUG set: #include <stdio.h> #include <mrf24j40.h> #include <mrf24j40_params.h>
int main\(void\)
mrf24j40\_t dev;
mrf24j40\_setup\(&dev, mrf24j40\_params\);
mrf24j40\_reset\(&dev\);
return 0;
This results in the following error from the mrf24j40_init function: [mrf24j40] Initialization failure, SPI interface communication failed
The only USEMODULE I've selected in the makefile is mrf24j40
My question here is what the best steps from here would be to find out what could cause SPI to fail, I feel a bit overwhelmed with the possible causes this could have and frankly have no idea what to check next. Is anything inherently wrong with my usage of the driver? Can I use the default params from mrf24j40_params.h without issues? Are any issues known with the stm32 boards and this radio chip? Is the only possible problem here the way I've connected it? Any specific pins not clear from the default params that need to be connected to either GND or VCC?
Any help or ideas would be greatly appreciated, thanks in advance
Nils
