Hi.
I’m doing a small project on STM32L0 where all the available physical UART ports are being used and I need to have one more serial port for debugging (will be off in production). I would like to know if there is any library in Riot OS like SoftwareSerial in Arduino?
Thanks in advance.
Regards.
There is soft_uart.
Unfortunately this is not a drop-in replacement for a ‘real’ UART, event though the API functions are compatible: All function names are prefixed with soft_ to avoid conflicts with the periph UART, so code that wants to use it needs some adoption (can be search & replace).
If you have a debugger you can also use STDIO over Semihosting.
This does not use up any UART peripherals.
Thank you! I think soft_uart is what I need!
The second option is very interesting because I also have a debugger.
