I’m getting several failures on MIPS with size_t vs int usage in this PR (#9368)
eg:
Building application "tests_driver_ata8520e" for "pic32-clicker" with MCU "mips_pic32mx".
main.c: In function 'ata8520e_sigfox_cmd':
main.c:84:24: error: format '%d' expects argument of type 'int', but argument 3 has type 'size_t' [-Werror=format=]
"message length is %d", SIGFOX_MAX_TX_LENGTH, strlen(argv[2]));
IIRC size_t is unsigned so the error is correct, how did this code get upstream, and how come no one else is getting this error ?
I presume the fact that this PR add SPI support for MIPS(PIC32) these drivers are now getting built for MIPS, but how is this not a failure on other architectures ?
Should I fix these in this PR or create another one ?
Neil
Hi Neil,
I suppose the toolchain is compiled with different default warning flags.
Usually another PR (or even multiples) are preferable. Trivial one-line
PR's are usually merged *very* quickly.
“and how come no one else is getting this error ?”
Probably you are the first to build it with GCC 7.x
It has stricter rules regarding variable types.
gcc version 4.9.2 (Codescape GNU Tools 2016.05-03 for MIPS MTI Bare Metal)
