I try to get sixlowpan and rpl to work but had no luck :(.
I want to compile an image for the msba2 board.
Ive included sixlowpan and rpl to USEMODULE in the Makefile of the default project.
Ive also included -I${RIOTBASE}/sys/net/sixlowpan/ to it.
I use a main.c (test_rpl) from the early days of RIOT as Jam was used.
I would like to ask if anyone has lately get the sixlowpan and/or the rpl module to run?
Martin
I ported the old sixlowpan code from ukleos to riot/projects, it's in master now.
Fixes for riot are in the queue (waiting for the merge of the pull request).
Code is building up, but I didn't check the binary...
Hope this helps you!
Christian
Hi Christian, hi Martin,
the merge is done, but still untested.
Oleg
