since I'm currently working on a test framework (with usage of CUnit)
and have a far-goal of getting libcoap to run on RIOT it raises the
question of how we deal with shared libraries (especially since we say
we support Wiselib). Since I did not found any way how wiselib was
introduced I use two approaches so far — both, shall we say,
suboptimal in my opinion:
* since I'm testing the test framework on the native port I'm just
*linking CUnit* with LFLAGS in the Makefile (meh, because of not
possible on "other" boards)
* my early draft of including libcoap was done by compiling as a *.a
file and just include it like a normal module (meh, because requieres
lib to be in RIOTPATH as a submodule and because it might be
problamatic if one tries to include proprietary (*gasp*) libraries).
So I'm either looking for ideas how to optimize one of the approaches
or incorperate support for shared libraries into RIOT.
on which branch of libcoap are you working? I am in the process of
restructuring a lot of things to improve support for foreign platforms
such as Contiki or LWIP. I did not have sorted out the right abstraction
level for this, hence suggestions are always appreciated.
One important change (others will follow) is in the branch
io-with-callbacks -- it offloads the network I/O from the library
itself.
