I am trying to implement a network using RPL and a DODAG with two levels.
Node 1 is communicating with node 2, and node 2 is communicating with node 3.
But when I create my network (using rpl_init) I have a root node (rank 256 in the DODAG) and the two other nodes are rank 512 in the DODAG. How can I create another node with rank 1024 in the DODAG for example ?
Is this implemented in RIOT ?
Thanks for your help,
Caroline QUEVA
Research Engineer at CEA-LIST
DRT/LIST/DACLE/LIALP
Laboratoire Infrastructures et Ateliers pour le Logiciel sur Puces
Commissariat à l’énergie atomique et aux énergies alternatives
MINATEC Campus | 17 rue des Martyrs | 38054 Grenoble Cedex 9
I am currently using tap devices as described in the link you sent, but didn't find the way to define a multi-hop network.
Should I use desvirt for multi-hop network ?
I looked at desvirt before and thought it was only for creating grid topologies and I would like to have a tree topology, is it possible ?
Caroline QUEVA
didn't find the way to define a multi-hop network. Should I use desvirt for
multi-hop network ?
Yes, that would be the way to go for a virtual multi-hop network.
Yes, this is possible. The topology_creator is part of desvirt and can help
you to configure simple standard topologies. Basically, it generates an XML
file in the .desvirt subdirectory that describes the topology. You can modify
this XML file in order to setup every desired topology.
Please take a look at the XML file(s) and let us know how self-explaining
you'll find them.
