I have seen the pull request from Troels51 concerning the SAMR21.
Is that normal that it uses the transceiver at86rf231 instead of the at86rf233? The SAMR21 Explained pro board uses the at86rf233 transceiver so something should be changed.
We did a little study on both and ended up with the conclusion, that actually both transceivers are quite similar. The xx233 is a little newer and has some added functionality regarding power management. But the basic register set (and register addresses) are identical which makes the x231 driver work perfectly also with the x233 device. Maybe we can rename the driver to at86rf23x and enable the additional features for the x233 per define. So feel free to open a PR! Yeah! Looking forward for the PR! Cheers, Hauke
We looked at both transceivers in detail and found, that they are more or less the same. The x233 is the newer brother of the x231 and hast some more options for low-power operation. But the base set of configuration registers and register addresses is identical for both devices, so the x231 driver works perfectly for the x233. Maybe for the future it would make sense to rename the driver to ‘at86rf23x’ and make the additional features of the x233 available per compile flag?! Feel free to propose a PR here Very nice, looking forward to it! Cheers, Hauke
There is also an rf212 which is a 868 MHz/900 MHz variant of the 230, and uses the same driver as rf230 (at least in Contiki) with the exact same commands and register addresses.
