Hi RIOTers,
I am trying to compile the latest rpl_udp example for my SAMR21 Xpro. The compile was fine but I had an error message from the link. It bailed out with a ram overflow error.
~/RIOT/examples/rpl_udp$ make BOARD=samr21-xpro
/home/user/gcc-arm-none-eabi-4_9-2014q4/bin/…/lib/gcc/arm-none-eabi/4.9.3/…/…/…/…/arm-none-eabi/bin/ld: /home/user/RIOT/examples/rpl_udp/bin/samr21-xpro/rpl_udp.elf section .bss' will not fit in region
ram’
/home/user/gcc-arm-none-eabi-4_9-2014q4/bin/…/lib/gcc/arm-none-eabi/4.9.3/…/…/…/…/arm-none-eabi/bin/ld: region `ram’ overflowed by 3544 bytes
make: *** [all] Error 1
The toolchain version is “gcc version 4.9.3 20141119 (release) [ARM/embedded-4_9-branch revision 218278] (GNU Tools for ARM Embedded Processors)”. The RIOT source code was pulled off github as of today. Any suggestion? Thanks.
Steve M.
