Dear all, I want to use the sam R21 Xpro with a GPRS plugin (Some friends from the electronics department will take care of the hardware connectivity). What changes should I perform to the Riot code? Thank you in advance!
Hi Ilias,
for you GPRS device you need to implement a device driver (which should implement the netdev2 interface to be able to integrate with out network stack(s).
Roughly you then need to do the following:
For not using the build in radio, you don’t have to change anything in the code, all you need to do is not use the USEMODULE=netif_default
in your applications Makefile… Instead you then simply tell the make system to use your GPRS device (something like USEMODULE=your_driver_name
) and add auto-initialization code for your device to sys/auto-init/netif/.
Cheers, Hauke
Thank you very much Hauke !!!
