Hey,
I've just ported our unittests for cbor to the new unittesting infrastructure
in tests/unittests.
Also see:
https://github.com/krf/RIOT/commit/e7626e14c734a17d0e574cbf92adc0c6f2a33135
My question: Is there an easy way to be able to just run our tests? I.e.
tests-cbor in this case? I think it would be quite helpful to run them
individually without having to recompile the unittests target.
E.g. by specifying tests-cbor via the command-line. Something along:
$ unittests.elf -test tests-cbor
Greets
you need to specify the tests to run at compile time, because other
boards than native don't have command line arguments. Use
tests/unittests$ make clean tests-cbor
tests/unittests$ make term
Or replace "tests-cbor" with any test suite you want to run. You can
specify multiple test suites, too.
Hope this is helpful.
René
From Testing RIOT · RIOT-OS/RIOT Wiki · GitHub via
tests/unittests/README.md:
If there are tests for a module you even can build tests specifically for this module:
make tests-<module>
# e.g.
make tests-core
Cheers, Ludwig
