I would like to run CC1101 transceiver on my custom board. I have already written all necessary peripherals drivers like usart, lpm, timers, spi, gpio and so on. I tested them using build in tests and run few of my testings programs.
My question is how to run a sample program utilizing the CC1101? I was analyzing the driver (btw basing on it I am writing CC1125 driver), it's API, but still making a simple program managing 6LoWPAN stack and transceiver is hard for me. My aim is to build a small testing mesh.
It should suffice to create a file "cc110x_params.h" with the correct
SPI/pin parameters and put it in your include path, then add "USEMODULE
+= cc110x gnrc_netdev2 gnrc_cc110x" to your makefile, in addition to the
other gnrc modules. I use gnrc_networking as a base and just add those
modules.
Check "boards/msba2/include/cc110x_params.h" for an example parameters
file, but make sure to adjust the settings.
Last time I tried there was a problem with 6lowpan IP header
compression, so if you can't communicate between nodes using IPv6, try
disabling iphc (by adding "DISABLE_MODULE += gnrc_sixlowpan_iphc" to the
application's Makefile).
