Hello everyone, the sensors in a WSN-Environment need very often to save as much power as possible. Therefore you have normally a power-profile when which device is sleeping/power-down-mode etc.. Before I make some trials with implementing such a scenario I want to hear some opinions/thoughts about the correct way to handle this with RIOT. As far as I see a good starting point is the example "timer_periodic_wakeup". This example configures the MCU to be in a periodic sleep mode. Question 1: What is the correct way to integrate the external devices (sensors, radio modules) into this scenario. I think the user has to configure the device to get into sleep mode and to wake up inside the while(1) loop by himself - like this: while(1) { make mesurement/send data bring the device into power-down mode xtimer_usleep_until...... wake up the device } Is this correct?
Question 2: How to handle the threads correctly in this scenario? For example you have a sensor and a radio modul. The sensor makes several measurements before the radio module sends data. If you make fork 2 threads - one for measurement and one for data-transmission - how could it be handled that the measurement thread should be invoked more often than the other thread.
Question 3: How to handle the threads in relationship with the "timer_periodic_wakeup" scenario.
Thank you for your hints! Best regards, Bernhard
