Hi! I try to port riot to CC430F5137 using a panstamp board ( http://www.panstamp.com/product/197/ ). I didn’t have any luck with the old msp430debug package which i’ve found in the latest ubuntu. The first thing I’ve tried to do is to get a simple UART example working, but when I’ve tried to enable the interrupts with: __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, interrupts enabled the whole thing freezed. I guess that some other kind of interrupt happens all the time, but I haven’t been able to debug it ( yet ). So I’ve started using TI’s / redhat’s gcc compiler, and it worked just ok ( under windows ). So I’ve moved on to this compiler, which I’ve installed by this tutorial: http://www.simplyembedded.org/tutorials/compile-install-msp430-gcc/ I’ve tried to use chronos version for the first time, I’ve deleted all the LCD headers, and modified stdio.h a little bit, so it doesn’t looks for these kind of files. The compilation worked previously with the obsolete mspgcc, so that worked somewhat. Now when I do BOARD=chronos make then it doesn’t finds msp430-gcc. So I’ve moved everything from opt/msp430-toolchain/bin ( the place where I’ve installed the new TI mspgcc ) to bin, so it found the new mspgcc compiler. Now it was missing the header file, I’ve modified the makefile.include so it found it now. There were some missing stuff , but I’ve solved these problems, but now I have this error: as: unrecognized option ‘-mP’ I’ve did a verbose output with make -n, this came out: http://pastebin.com/BDQjdaJG I have found -mP but only with msp430-gcc, and there is no as program as far as I know, so I doesn’t really understand this.
My first question is: how to install this compiler properly, so that whenever I use msp430-gcc then this new compiler will be called? I’ve also tried to use the installer…sh file from ti, but it doesn’t install it to /bin or anything in the $PATH so I can’t use it with the current makefiles. The current solution is…hmm kind of ugly and doesn’t works
The second question: Should I use the obsolete ti compiler instead? What causes this bug?
The third one is: What is this as / -mp thing?
Thanks for any help, and sorry for my ugly English. Viktor
