Dear reviewing IoTlers,
looking at https://github.com/RIOT-OS/RIOT/pull/5758, I just realized that our
convention to add squash commits while a PR is under review may need an
amendment. If all commits that addresses a certain comment and are meant for
squashing have a non-speaking commit message (see linked PR), then it gets
more time-consuming for the reviewer to map a commit to a certain
review-reaction. Hence, I would propose to somehow reference the addressed
comment in the commit message. What do you think?
Oleg
Hi!
That would rule out --fixup commits (and thus automatic rebasing). "git
commit --squash" allows adding to the commit message, but the commit
subject stays the same, so in order to improve things, one would have to
unfold the whole message in git's PR overview.
Actually, I've never found a big advantage in automatic rebasing. If you
specify both, the addressed comment and the corresponding commit in the commit
message, interactive rebasing can be done in no time.
A potential other solution would be to use something like Gerrit, but I guess
no one here wants this.
Oleg
Not necessarily. I would put such links to comments in the commit body
anyway and that is ignored by --autosquash.
hm, that makes it rather inconvenient to review - particular with the "new"
shitty GitHub UI.
> commit
Well you still have to read and compare every single commit, which
--autosquash just takes a way. So you still need way more time.
Yes, it takes more time, but just a few seconds if the commit messages are
sensible. I never use autosquashing.
Oleg
Not necessarily what?
Rule out --fixup commits
Did you read my email? You cannot change the commit message of --fixup
commits - it is always "!fixup <original commit message subject>"
without body. You can add a body when using "--squash" (the subject will
always be "!squash <original subject>", but that body would always get
folded away by the github interface. If anyone would like to see a
comment you've added to such a commit, you have to press the little
"..." icon.
