Dear relentless RIOTers,
I would like to introduce an official repository for keeping Dockerfiles used for building Docker images. The images can be used to build RIOT in conjunction with the work being proposed in 1. The images will contain supported versions of tool chains to make getting started with RIOT more convenient. I volunteer as maintainer for the Dockerfile repository and the pre-built images which will be published at the Docker hub 2. The reason for making a separate repository instead of using /dist/XXXXX is that we can more easily keep track of tool chain updates, and we can use the Docker hub automatic build feature to automatically update the images. Using the core RIOT code repo for Dockerfiles will cause an unnecessary amount of rebuilds when watching it with the automatic build feature of the Docker hub.
Joakim
fine with me, thank you for the initiative =)
Ludwig
I'd like to hear if anyone is strongly opposed to this, otherwise I
will go ahead and create a new repository tomorrow.
Joakim Gebart
www.eistec.se
Hi Joakim!
I'm completely fine with that. Thanks for the effort!
Oleg
What is a suitable name for the new repo?
I have been using "riotbuild" for my Docker development at
https://github.com/gebart/riotbuild
Also, I need to have an organisation owner (Oleg, Kaspar, Emmanuel or
Matthias Wählisch) create the repo since maintainers do not have the
proper access to do it.
Joakim Gebart
www.eistec.se
Hi Joakim!
I don't have any particular ideas for the name, so, for me "riotbuild" (or
"riotdocker") would be fine.
Matthias Wählisch) create the repo since maintainers do not have the proper
access to do it.
Sure, I can do so. Let's wait if no one objects against the proposed name.
Oleg
riotdocker is more descriptive for the github repo name, I like it.
Best regards, Joakim
+1 for riotdocker, riotbuild is confusing.
Cheers
matthias
Hi!
> access to do it.
This somehow disappeared from my radar. I think you need to give me admin
access to the repository in order to move it to the RIOT organization (and
rename it to riotdocker).
Oleg
Hi!
> access to do it.
What do you mean?
If you create a new empty riotdocker repo in the RIOT organization we
can push the Dockerfile commits to it.
Hi Joakim!
What do you mean?
Yes, of course that's possible. I thought it might be easier to move the
already existing repository to the RIOT-OS organization, but anyway here we
go:
https://github.com/RIOT-OS/riotdocker
You should have write access.
Oleg
Hi Joakim,
I assume you "own" the RIOT organization on docker.com. Can you add the
RIOT-OS/riotdocker?
Oleg
Hi Joakim,
RIOT-OS/riotdocker?
I have now added it under the name riot/riotbuild
https://registry.hub.docker.com/u/riot/riotbuild/ (I figured the
docker suffix on a Docker hub repo is kind of redundant)
It needs further configuration on the GitHub side by an administrator,
follow the instructions on this page for the RIOT/riotdocker
repository:
https://docs.docker.com/docker-hub/builds/#github-service-hooks
Oleg: Do you have a docker hub account? I can add you as an
administrator to the riot organization.
The Dockerfile is building, but there seems to be some problem with
the Debian mirrors at the moment, I'll retry later.
https://registry.hub.docker.com/u/riot/riotbuild/builds_history/163750/
BR,
Joakim
Hi Joakim!
Great!
repository:
Ok, I'll do that.
Yes, I registered yesterday as "oleghahm"
(https://registry.hub.docker.com/u/oleghahm/
Oleg
