There’ll be the release of Rust 1.60 on 2022-04-07, a day after hard freeze. It would be kind of nice to get “works with stable Rust on all platforms” in for the April release, and all can be tested on beta already, but the final change that replaces ‘beta’ with ‘stable’ could only happen on the 7th, and would need to start in riotdocker and then propagate to the builders.
All changes on the RIOT and Rust code side are already in place, it’s more a matter of tooling. Is this something you’d consider shifting the hard freeze date (or consider the switch from beta to stable not a feature but a fix), or should I leave this for the next release (whose release manager, I’m told, is a big fan of Rust )?
if I understand this correctly, it would be just a string substitution and
shouldn’t affect any result, right?
In this case, I would argue that the cleanest solution would be to postpone
the hard freeze by two days.
Cheers
Oleg
panic(“kmem_cache_init(): Offsets are wrong - I’ve been messed with!”);
linux-2.2.16/mm/slab.c
Well, the string substitution will pull in a different build of the compiler. But the whole point of the beta is to be (or, in the weeks until it is release, become) no different than the released stable version, so I expect the effect to be that of a string substitution.
