Hello!
I have a problem when executing make BOARD=stm32f4discovery in the directory: $(RIOT)/examples/hello-world/.
The output is like this:
I use the cross complier “gcc-arm-none-eabi-4_8-2014q2” and set the $PATH correctly.
Something seems wrong because some of the exectuable files are vacuum, like this
Then execute arm-none-eabi-gcc -v,there is no response,like this.
How can I solve this problem and let the system work? T_T
Thanks for your reading!
Dongyu from Zhejiang, China
Hi Dongyu,
the empty entries should be links to corresponding files in other directories.
For example /opt/arm-none-eabi-4_8-2014q2/bin/arm-none-eabi-gcc
should be a link to /opt/arm-none-eabi-4_8-2014q2/arm-none-eabi/bin/gcc
I suggest that something went wrong during decompression of the gcc-arm-none-eabi-4_8-2014q2-20140609-linux.tar.bz2
archive to /opt/
You could try to decompress the archive somewhere in your home
directory, and check if you can run the arm-none-eabi-gcc -v
from there.
Martin
I think your PATH does not include the directory where arm gcc lives or your extraction process went wrong.
To check the PATH go in a random directory (e.g. your home or RIOT folder) and enter
On my machine this shows:
$ arm-none-eabi-gcc -v
Using built-in specs.
COLLECT_GCC=/usr/bin/arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/arm-none-eabi/4.8.1/lto-wrapper
Target: arm-none-eabi
Configured with: ../gcc-4.8-2013.11/configure --prefix=/usr --mandir=/usr/share/man --libdir=/usr/lib64 --with-pkgversion='Fedora 2013.11.24-2.fc20' --with-bugurl=https://bugzilla.redhat.com/ --enable-lto --infodir=/usr/share/info --target=arm-none-eabi --enable-interwork --enable-multilib --with-newlib --enable-languages=c,c++ --disable-nls --disable-shared --disable-threads --with-gnu-as --with-gnu-ld --with-gmp --with-mpfr --with-mpc --with-newlib --with-headers=/usr/arm-none-eabi/include --with-system-zlib
Thread model: single
gcc version 4.8.1 (Fedora 2013.11.24-2.fc20)
The right tar file is available via this page:
https://github.com/RIOT-OS/RIOT/wiki/Family:-ARM
For the Cortex CPUs we recommend the Linaro package, for ARM7 the Codebench.
Let us know what the solution is!
Best
Christian
