Hello everyone, I would like to know if anyone was able to even build the hello world example for ESP32.
I’m trying to make an app using mqtt-paho, because I couldn’ t make it work on native build, but I’m pretty sure it works (or I least it should work ) and as with the ESP32 I can reach WIFI, was trying to build an example to this board.
It seems that the documentation is using a reference on ESP-IDF that doesn’t exist anymore. And with newer release versions of esp-idf, it just doesn’t work the build.
and the latest RIOT release as well as the current master.
Could you please provide a hint where the documentation refers to an
ESP-IDF version that no longer exists? Wrong references are sometimes
leftovers in the documentation that were simply forgotten when the
toolchain was changed
I developed an application with mqtt-paho myself, also on an esp32 using wifi. In case you don’t know this yet, I would like to give you the following hints:
(1) RIOT supports only MQTT-SN and as far as I know paho.mqtt-sn.embedded-c is the only paho variant with MQTT-SN support. So you will have to use this one.
(2) You will need to set up UDP6 in the configuration of paho.
(3) Don’t make the same mistake as I did when I started working with the master branch of paho.mqtt-sn.embedded-c. Instead use the develop branch, because it’s much more recent (last commit in master was in July 2019 vs. April 2020 in develop). The configuration sketch for UDP6 is missing completely for example in master.
If you get in to trouble to get a connection don’t hesitate to ask me. I lost quite some time back then when trying to figure out how to get my project working, essentially because paho’s documentation is a mess*.*
