Proposal: per-module code coverage reports for tests/unittests on native
Hi everyone,
I’ve been exploring RIOT’s test infrastructure recently and noticed there’s no automated code coverage reporting in CI. I found the 2020 forum thread on this topic which raised some valid concerns — aggregate coverage numbers are misleading, optimized builds complicate line mapping, and RIOT’s modular compilation means a single percentage hides a lot. I think those concerns are right, and they point toward a more focused scope than “measure everything.”
What I’m proposing
Rather than a codebase-wide coverage number, generate per-module HTML/LCOV reports scoped specifically to tests/unittests on BOARD=native. The approach would be:
  1. Compile with -fprofile-arcs -ftest-coverage -O0 -fno-inline
  2. Run the unit tests as a Linux process (no hardware needed)
  3. Generate per-module reports with lcov/genhtml
  4. Publish as a Murdock artifact or nightly job output
Scoping to tests/unittests and native sidesteps the hard problems — no cross-compilation, no hardware, no misleading aggregate. Per-module reports answer a concrete question: “is this function ever called by any test?” That alone would give contributors clear targets for improving test coverage in core/ and sys/.
I am not proposing:
  • A coverage gate on PRs
  • Coverage for drivers/, periph/, or cpu/ (hardware-dependent, not useful without emulation)
  • A single percentage target to chase
Before I put together a proof-of-concept PR, I have a few questions:
  1. Is there a known issue with gcov on the native port specifically — for example, interaction with the ucontext/signal-based threading that might produce misleading results?
  2. Would a separate make coverage target be the right place for this, or does Murdock have a better integration point?
  3. Is there a preference on where reports get published — Coveralls, Codecov, or self-hosted HTML artifacts?
  4. Has anyone tried this before and run into a specific wall that killed the effort?
Would love to hear if this is worth pursuing or if there are blockers I’m not aware of.
Hi @seyoung, welcome to the forum! As pointed out in your issue (and in the thread you point to): there was some preliminary work done by @nmeum on this already: Import coverage generation module from Zephyr by nmeum · Pull Request #17000 · RIOT-OS/RIOT · GitHub. Maybe you can pick that up, so you do not need to start from zero.
I can’t answer any of your detailed questions, but your plan sounds like a good way forward.
