Hello everyone
I am trying to retrieve an IPv6 address with the “highest” avaible scope and convert it into a string. While retrieving the IP addresses and determining their scope works fine I have, however, problems converting an ipv6_addr_t *
pointer into a sting using ipv6_addr_to_str
. Despite the fact that I used the same code as in the definition of ipv6_addr_print
(see here), ipv6_addr_to_str
changes the ip address that is represented by the string. Using ipv6_addr_print
itself, however, prints out the correct result. I encountered this behavior both on native as well as on an ESP32.
Is there some way for me to fix this or could this be a bug within the ipv6_addr_to_str
function? Thanks in advance!
You should be able to reproduce the problem using the following code and make all term
main.c:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <stdbool.h>
#include "xtimer.h"
#include "shell.h"
#include "fmt.h"
#include "net/netif.h"
#include "net/ipv6/addr.h"
#define MAIN_QUEUE_SIZE (4)
static msg_t _main_msg_queue[MAIN_QUEUE_SIZE];
static ipv6_addr_t *get_base_ip_address(void){
const int MAX_ADRESSES_TO_CHECK = 5;
netif_t* interface = NULL;
ipv6_addr_t* local_address = NULL;
ipv6_addr_t* ula_address = NULL;
while ((interface = netif_iter(interface)) != NULL) {
ipv6_addr_t adresses[MAX_ADRESSES_TO_CHECK];
netif_get_opt(interface, NETOPT_IPV6_ADDR, 0, adresses, sizeof(adresses));
for (int i = 0; i < MAX_ADRESSES_TO_CHECK; i++)
ipv6_addr_t* current_address = &adresses[i];
if (current_address == NULL) {
break;
printf("Loop begin\n");
if (ipv6_addr_is_global(current_address)) {
printf("Global address: ");
ipv6_addr_print(current_address);
printf("\n");
printf("Loop end\n");
return current_address;
else if (ipv6_addr_is_unique_local_unicast(current_address)) {
printf("Unique local unicast: ");
ula_address = current_address;
else if (ipv6_addr_is_link_local(current_address)) {
printf("Link local address: ");
local_address = current_address;
printf("\n");
if (ula_address != NULL) {
return ula_address;
return 0;
else if (local_address != NULL) {
return local_address;
return NULL;
int ip_test_cmd(int argc, char **argv)
if (argc != 2)
(void)puts("Usage: iptest test");
return 1;
if (strcmp(argv[1], "test") == 0)
char address_as_string[IPV6_ADDR_MAX_STR_LEN];
ipv6_addr_t *base_ip_adress = get_base_ip_address();
assert(base_ip_adress);
printf("ipv6_addr_print:\n");
ipv6_addr_print(base_ip_adress);
printf("\nipv6_addr_to_str:\n");
ipv6_addr_to_str(address_as_string, base_ip_adress, sizeof(address_as_string));
print_str(address_as_string);
printf("\n");
return 0;
return 1;
static const shell_command_t shell_commands[] = {
{"iptest", "Get an IP address of the highest order possible.", ip_test_cmd},
{NULL, NULL, NULL}};
int main(void)
xtimer_sleep(3);
/* for the thread running the shell */
msg_init_queue(_main_msg_queue, MAIN_QUEUE_SIZE);
/* start shell */
puts("All up, running the shell now");
char line_buf[SHELL_DEFAULT_BUFSIZE];
shell_run(shell_commands, line_buf, SHELL_DEFAULT_BUFSIZE);
return 0;
Makefile:
# name of your application
APPLICATION = ipaddr_test
# If no BOARD is found in the environment, use this default:
BOARD ?= native
# This has to be the absolute path to the RIOT base directory:
RIOTBASE ?= $(CURDIR)/../..
# Include packages that pull up and auto-init the link layer.
# NOTE: 6LoWPAN will be included if IEEE802.15.4 devices are present
USEMODULE += gnrc_netdev_default
USEMODULE += auto_init_gnrc_netif
# Activate ICMPv6 error messages
USEMODULE += gnrc_icmpv6_error
# Specify the mandatory networking modules for IPv6 and UDP
USEMODULE += gnrc_ipv6_router_default
USEMODULE += gnrc_udp
# Add a routing protocol
USEMODULE += gnrc_rpl
USEMODULE += auto_init_gnrc_rpl
# This application dumps received packets to STDIO using the pktdump module
USEMODULE += gnrc_pktdump
# Additional networking modules that can be dropped if not needed
USEMODULE += gnrc_icmpv6_echo
# Add also the shell, some shell commands
USEMODULE += shell
USEMODULE += shell_commands
USEMODULE += ps
USEMODULE += netstats_l2
USEMODULE += netstats_ipv6
USEMODULE += netstats_rpl
USEMODULE += fmt
# Comment this out to disable code in RIOT that does safety checking
# which is not needed in a production environment but helps in the
# development process:
DEVELHELP ?= 1
# Change this to 0 show compiler invocation lines by default:
QUIET ?= 1
include $(RIOTBASE)/Makefile.include
