I'm testing three different boards and native mode RIOT. It seems I may have a problem with printing 64 bit ints (for example, an EUI-64 address). Here's the code fragment (modified from examples/hello-world.c):
uint64_t longnum = 0x1234567812345678;
puts("Hello World!");
printf("You are running RIOT on a(n) %s board.\n", RIOT_BOARD);
printf("This board features a(n) %s MCU.\n", RIOT_MCU);
printf("longnum %016"PRIx64" %016llx\n", longnum, longnum);
Here's a summary of the output from the 4 devices:
cc2538dk: longnum 1234567820001350 1234567812345678
samr21-xpro: longnum 000000000000000lx 000000000000000lx
redbee-econotag: longnum 1234567812345678 1234567812345678
native: longnum 1234567812345678 1234567812345678
and the compilers I'm using for each:
cc2538dk: gcc version 4.3.2 (Sourcery G++ Lite 2008q3-66)
samr21-xpro: gcc version 4.9.3 20141119 (release) [ARM/embedded-4_9-branch revision 218278] (GNU Tools for ARM Embedded Processors)
redbee-econotag: gcc version 4.3.2 (Sourcery G++ Lite 2008q3-66)
native: gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1)
Is there something I'm doing that's obviously wrong?
- Ralph
Hi Ralph!
I guess this problem is related to the Newlib-Nano [1] we're using if the
toolchain supports it. This library doesn't support 64-bit printing. If it's
required for you, you could try to disable it in the Makefile
(e.g. boards/samr21-xpro/Makefile.include, for the Atmel board), but you may
run into memory problems then.
Oleg
[1] https://github.com/32bitmicro/newlib-nano-1.0
Hi Ralph!
Ah, OK. Is printing the only limitation to use of 64-bit datatypes?
- Ralph
Hi Ralph!
Yes, everything else regarding 64-bit datatypes should work as expected.
Oleg
