Thanks for the recent release ! It’s nice and a good job !
But I have a problem with the posix_sockets example. I try to use it to send messages from one node to another using udp, but the udp server is only receiving the first 28 messages, after that no more message is received.
Does it happen for other people too ?
Does anyone have an idea about why it happens ?
Thanks for your help,
Caroline
Caroline,
Sorry for the late response.
Thanks for the recent release ! It's nice and a good job !
Thanks for the nice words!
Right now, I have no idea what could go wrong. In fact, I could successfully
run experiments over 7 days with 10,000 pings. Which hardware are you using?
Have you checked if you experience the same problem without POSIX sockets,
e.g. using the gnrc_networking example?
Oleg
Hi Oleg,
Thanks for your answer,
I am currently using posix-sockets in native with desvirt to create my network's topology.
I don't think I had the same problem with gnrc_networking (without POSIX sockets) but I decided to use POSIX sockets to receive the udp payload in the application's thread and be able to print it or do extra calculations with it.
Are you using POSIX sockets too or the gnrc_networking example ?
Caroline QUEVA
Research Engineer at CEA-LIST
DRT/LIST/DACLE/LIALP
Laboratoire Infrastructures et Ateliers pour le Logiciel sur Puces
Commissariat à l’énergie atomique et aux énergies alternatives
MINATEC Campus | 17 rue des Martyrs | 38054 Grenoble Cedex 9
Caroline,
with it.
I'm using gnrc_networking. You could try to use the conn_api and see if the
problem persists. It should give you a very similar interface for the
application as POSIX sockets do.
Oleg
