I intend to port RIOT to ESP32-H2.
Does anyone know what the progress is on upgrading ESP-IDF to version 5.1?
This pull request suggests that the toolchain needs to be updated:
Is there a way I can help?
Unfortunately the upgrade to ESP-IDF 5.1 is much more than just a version bump, it requires a lot of rework. The reason is that we canât use ESP-IDF like an SDK, because ESP-IDF is based on FreeRTOS, which is an integral part of it. Instead, we just compile a set of required source files of the ESP-IDF. These ESP-IDF source files, in turn, require functions to be provided by RIOT. Since ESP-IDF changes a lot with each new version, all these parts have to be reworked.
I had hoped to find time in the last half year to do this rework and get ESP32-C6 and ESP32-H2 working. Unfortunately I did not manage to do it.
What are the main tasks:
I suppose that the rework takes at least 2 or even more man months.
how can we apply more eyes to this? Would you be able to make a list of the new functions?
@gschorcht I saw the progress in your PR. Very good. I would like to try this port out. ESP32-C6 or ESP32-H2? Can you recommend something specific? Aliexpress shows me uncountable number of possible ESP32-H2 boards. I canât tell which ones have 802.15.4, or if they all do.
I only have the original devkits from Espressif ESP32-H2-DevKitM-1, but I guess that all the boards available from AliExpress are just clones of that. So it shouldân matter what board you order.
IEEEE 802.15.4 is not a feature of the board but a feature of the ESP32-H2.
Regards Gunar
