Hi all
I’m new to Riot OS and doing a little activity with the Nucleo L432KC board and the MOD-WIFI-ESP8266-DEV connected to Nucleo L432KC. For now I can connect to the MOD-WIFI-ESP8266-DEV to a WIFI AP running a UART command from Nucleo L432KC, provide the credentials for the WIFI access point and connect to it successfully - wifi board is assigned with a correct IP address. It works great and I’m happy ![]()
My question is: how can I send an HTTP request from the Nucleo L432KC in this configuration and then read the response?
I’m stuck with this and would appreciate your help.
I can’t seem to send HTTP requests over the UART - HTTP AT commands are not available for MOD-WIFI-ESP8266-DEV
Sample of UART data exchange
This is RIOT! (Version: 2022.07)
UART
result: 0
send UART command (len=8): AT+GMR
118 --> AT+GMR
AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:44:22
OK
send UART command (len=13): AT+CWMODE=3
20 --> AT+CWMODE=3
OK
send UART command (len=38): AT+CWJAP="HIDDEN","HIDDEN"
91 --> AT+CWJAP="HIDDEN","HIDDEN"
WIFI DISCONNECT
WIFI CONNECTED
WIFI GOT IP
OK
send UART command (len=11): AT+CIPAP?
105 --> AT+CIPAP?
+CIPAP:ip:"192.168.4.1"
+CIPAP:gateway:"192.168.4.1"
+CIPAP:netmask:"255.255.255.0"
OK
send UART command (len=12): AT+CIPSTA?
113 --> AT+CIPSTA?
+CIPSTA:ip:"192.168.10.162"
+CIPSTA:gateway:"192.168.10.1"
+CIPSTA:netmask:"255.255.255.0"
OK
