roh
1 April 2021 14:18
#1
I‘ve had some trouble using I2C(1) bus on a nucleo-f303re board.
After reading the stm32f303re datasheet and changing some parameter values in boards/nucleo-f303re/include/periph_config.h
before:
.dev = I2C3,
.sda_pin = GPIO_PIN(PORT_A, 5),
.scl_af = GPIO_AF5,
now:
.dev = I2C3,
.sda_pin = GPIO_PIN(PORT_B, 5),
.scl_af = GPIO_AF3,
everything worked fine. Should those values also be changed in the RIOT repository? Did I understand something wrong?
It’s well possible that you’ve found a bug - want to submit a Pull Request?
roh
2 April 2021 07:41
#3
Hi Ben,
thank you, as I’m not familiar with github processes, I would like to leave the bugfix - if it is a bug - to the maintainer.
It’s actually pretty simple:
Fork the RIOT repository in the GitHub UI
create a branch in git that contains the commit with the fix
push the branch to your RIOT fork on Github
create a pull request in the GitHub UI (it will automatically suggest to create a PR if you’ve just pushed a branch to your fork)
roh
3 April 2021 04:28
#5
I’m convinced (PR #16275 ), lets see what the reviewers will say.
