2026.05 VMA
Date: 2026-06-02
Time: 15:00 CET
Moderator: Ann
Notes: Mikolai
Venue: Jitsi Meet
This VMA planning forum entry: https://forum.riot-os.org/t/2026-04-vma-planning/4878
Previous VMA notes forum entry: Notes: Virtual Maintainer Assembly 2026.02
Attendees
- Koen
- Ann
- crasbe
- Martine
- Tom
- maribu
- Teufelchen
- Karl
- Lasse
- Mikolai
- benpicco (+12)
Agenda
- Agenda Bashing - (Ann) 3’
- 2026.04 Release Debrief - (Ann) 4’
- 2026.04.01 Release Debrief - (Ann) 1’
- Outlook on Upcoming 2026.07 Release - (MCR) 3’
- Upcoming Roles - (Ann) 5’
- 2026.07 Release Manager MCR
- 2026.10 Release Manager
- 2026.07 VMA Moderator
- How do we deal with AI in RIOT - (Ann) ?’
- How do we deal with doxygen errors - (Karl) ?’
- LTO - (Is this you Maribu?) ?’
- Codeberg: RIOT or RIOT-OS as Org name? - (emailed to Ann) 3’
- RIOT Security List & Repo Ownership (Teufelchen) ?’
- Python: Inline Metadata based on PEP 723 (Previous PR discussion) - 3’
- Ariel OS community day (Koen) - 5’
- AOB
Notes
- Ann: Release-Specs annoying, some part didn’t work with IoT-lab, was unable to register at IoT-Lab
- Mikolai: Notes?
- Ann: yes, in release issue
- Tom: did you nag other people to help with testing? it’s not manager’s job to do everything alone
- Ann: yes, had some help
- Ann: released tarball was broken since some releases back, fixed that for this release
- Ann: MCR absent
- Tom: will help doing practical tests, have yet to start coordinating with MCR, seems responsive
Upcoming Roles
- MCR (+Tom) already, hurray
- https://crystalball.riot-os.org/
- crystalball selects Mikolai, Mikolai accepts, Martine offers help depending on time
- 2026.08 VMA Moderator
- AnnsAnn volunteered, Martine as backup
- Ann: Our current policy: Declare AI usage but also ¯\(ツ)/¯
- https://github.com/RIOT-OS/RIOT/pull/22004 < ¿more detail declaration?
- RIOT Examples
- The Student Saga
- pkg/pqm4: add ML-DSA-44 (FIPS 204) post-quantum signature package by cakirmert · Pull Request #22268 · RIOT-OS/RIOT · GitHub
- cpu/rp2350_common/periph/uart: fix PL011 FIFO handling by cakirmert · Pull Request #22269 · RIOT-OS/RIOT · GitHub
- cpu/rp2350_common: add periph_timer driver for TIMER0 by cakirmert · Pull Request #22270 · RIOT-OS/RIOT · GitHub
- cpu/rp2350_common/periph/uart: enable RX/TX FIFO and fix related ISR/TX flow by cakirmert · Pull Request #22297 · RIOT-OS/RIOT · GitHub (His “hand written” PR after being asked to do it by hand)
- Claude Code and open about it (but PR was rough intitially)
- Fully automated / OpenClaw? but trivial change
- More positive example of valuable contributions with Claude assistence (baptleduc)
- The Student Saga
- Ann: self-declaration of AI usage is difficult - those who should do it, don’t, for others its annoying
- Ann: unclear what to do with information, review PRs, finally merge?
- How other projects have dealt with it
- Zig (Full Ban w/ reasoning why): Contributor Poker and Zig's AI Ban | Loris Cro's Blog
- LLVM (Human-in-the-loop policy): LLVM AI Tool Use Policy — LLVM 23.0.0git documentation
- Zephyr (Must claim copyright): Contribution Guidelines — Zephyr Project Documentation
- Linux follows same system: AI Coding Assistants — The Linux Kernel documentation
- Ariel OS seems to also follow their DCO concept (Though no direct AI mention) ariel-os/CONTRIBUTING.md at main · ariel-os/ariel-os · GitHub
- Zed IDE (Very pro AI, still vibecoding = rejection): zed/CONTRIBUTING.md at main · zed-industries/zed · GitHub
- ghostty
- AI policy: AI usage must be disclosed; human-in-the-loop must fully understand all code
- With a vouch system for first time contributors, to prevent low quality AI contributions
- Flathub (Full AI ban)
- Karl: “must claim copyright”, who can claim that for LLM-generated code
- benpicco: spirit is out of the bottle, doesn’t make sense to fully ban it. declaration approach is good
- Martine: VSCode et al. has AI deeply integrated nowadays
- Ann: agree. annoying is vibe-coding
- Martine: these can be instant-closed
- Ann: tried with student-saga student, didn’t work out
- Teufelchen: close without comment?
- Tom: you can always reopen. taking valuable maintainer time if AI-contributors didn’t even invest time
- benpicco: EFM-ethernet driver is a good AI-generated example, actually good code
- Martine: true for people who know coding, people we know
- Tom: agreement: declare what you use. if requesting review, take at least the same time reviewing your own code
- Ann: sounds similar to LLVM-policy
- Martine: just adopt it? (similar to how we did with Code of Conduct from django) and adjust during review
=> Action Item: Steal^w copy LLVM policy, file a PR with that, discuss last details in PR
- Ann will open PR
- Karl: “not-documented” errors handled by exclusion scripts, but we don’t tell doxygen that we accept not-documented stuff
- Martine: originally because of doxygen version jump, all of the sudden required much more documentation - if that’s not the case anymore, we should fix it
- maribu: so without this workaround we would be stuck with 20-year-old doxygen
- Teufelchen: got a plant
- Mikolai: not relaxing doxygen in general, not document unnecessary stuff → have clear guidance on what can/should be excluded with the script
- karl: agree, script sometimes hides real errors
- maribu: one problem is static inline in headers, with need copy documentation every implementation of the same API (e.g. once in every board)
- Martine: wouldn’t we like to switch away from doxygen if some alternative is available? so don’t put too much effort in it
- crasbe: guidance in coding convention could be extended
- maribu: not my topic, but happy to speak about it
- maribu: we could stop using static inline if we behaved like we had LTO, static inline also harms C++/Rust integration
- karl: not supported at all by some strange architectures?
- maribu: I think it is mostly bugs on our side that prevent it from working
- maribu: start avoiding static inlines, that increases pressure to fix LTO bugs
- Mikolai: list of issues with LTO?
- Teufelchen: need to adapt old code for better integration?
- benpicco: what are benefits?
- karl: so above: better documentation
- Mikolai: also better Rust integration
- Ann: who volunteers to adapt coding convention for static inline?
- karl: better other way around: start using LTO, then maybe remove static inlines
- maribu: but first way would put pressure on fixing LTO bugs
- Teufelchen: action item - enable LTO on master, maybe include in next release
- maribu: instead of
LTO=1Makefile flag, we could declare LTO as feature, disable for specific cases - Benpiccos test PR: buildsystem: enable LTO by default by benpicco · Pull Request #22338 · RIOT-OS/RIOT · GitHub
- revisit at next VMA?
- Ann: got approached by people who were wondering about it
- Martine: Riot Games?
- Mikolai: reason?
- Ann: consistency with RIOT-OS name on Github
- Mikolai: but doesn’t fit with general stance of RIOT being umbrella and RIOT-OS being one part of it
- postponed to next VMA
- Teufelchen: Ann couldn’t see security, we noticed that repo ownership is all over the place. We probably need a cleanup.
- Teufelchen: main important is security, currently only 4 people (chrysn, kaspar, koen, Teufelchen), so effectively only Teufelchen
- Ann: why having separate security level?
- Martine: IMO all maintainers should see them
- rough consensus in the room
- Martine: will change it
- Koen (on chat): Handling GitHub Security Advisories
- Martine: also admins can see it
- benpicco: why do we have admins that haven’t been active in RIOT for years
- Ann: even owners
- Martine: owners are Matthias, Thomas, Oleg, Emmanuel and Kaspar
- Martine: we have maintainer ping, we can do an admin ping
- Ann: has it ever been done?
- Teufelchen: propose new rule: automatically remove after 2 years of inactivity on Github. much easier than maintainer ping
- Martine: leave forum list of maintainers, but remove Github rights after 2 years
- Martine: probably need to adapt governance doc accordingly, and someone should go through maintainer list
- Ann: could just introduce new policy over time, benpicco can do maintainer ping again
- karl: can we open “maintainer-ping PR”, everyone who does not ACK is removed
Looks like we have consensus to remove poeple from github-access-roles (e.g. Maintainers group) once they are inactive on github for more than two years
Maribu idea:
#### Removing a Maintainer
Maintainers may resign at any time if they feel that they will not be able to continue fulfilling
their project duties.
Maintainers may also be removed after being inactive, upon failure to fulfill their Maintainer
responsibilities or because of violating the Code of Conduct. This also includes actively,
persistently, and intentionally trying to harm or successfully harming the code base of RIOT.
Especially, but not limited to, endangering the security or safety of RIOT.
#### Retiring a Maintainer
A maintainer that has not shown a single interaction in a pull request or issue that took more than
5 minutes of effort over a period of 2 years will be retired and all permissions to the repository
will be revoked. The reason is that any account can be compromised. For maintainers that make
active use of the permissions, this risk is justified.
A retired maintainer will keep their permissions in the forum and their access to the internal
maintainer matrix room. In addition, a retired maintainer may return to active maintainer duty
at any point in time by reaching out to an admin to restore their permissions. A retired
maintainer that returned to active duty can be retired again for inactivy in the past 2 years,
but sooner than three months after restoring their permission.
Ann: dependencies can nowadays be inlined in Python files, standardized way understood by many environments
Mikolai: iirc, ubuntu 22.04 does not support it, thats what we use in riotdocker
Karl: but its only python comment, so should be ignored
Mikolai: true
Ann: so no opposition in room to move to this
crasbe: regarding riotdocker, could be updated, but things will probably break
Ariel OS Community Day
See: The 1st Ariel OS Community Day (1AD)
The other IoT OS written in Rust picked September 1 for its first community day in a pleasant venue in Grenoble. Co-hosting is nice and keeps the community together while allowing visitors for only one of the OS’s to also see the other.
In the mean time Tock OS / OxidOS is interested in hosting a day on the Monday (31st of August) and making it a week of IoT OS’s. Depends on whether the venue is also available on Monday.
Koen: would be nice to make it a collaborative event week Teufelchen: indeed. hackathon could be framed like shared social/interaction event Koen: could lead to increase attendees count for all three events Ann: IMO valuable for all three events
