Hello again,
Apologies, if I am becoming a nuisance to you guys. But I really want to be able to get the RIOT OS working so that I can include it within my Honours project.
I have managed to get a few more toys to play with e.g. a couple of Udoo NEOs, a BeagleBone and a Waspmote-Pro. Currently I am testing out the gnrc_networking application on the Waspmote-pro but I am having some issues when trying to run it. For an example, all I am getting is the “pyterm shell” and nothing else:
baksiso@baksiso-Lenovo-G580:~/RIOT/examples/gnrc_networking$ make term /home/baksiso/RIOT/dist/tools/pyterm/pyterm -p “/dev/ttyUSB0” -b “9600” No handlers could be found for logger “root” 2018-07-12 02:13:38,166 - INFO # Connect to serial port /dev/ttyUSB0 Welcome to pyterm! Type ‘/exit’ to exit.
However, I am able to run the “default” application or the “hello-world” and they worked perfectly.
Additionally, when I tried to flash the application onto the boar, I was getting the following:
text data bss dec hex filename 78024 11250 9732 99006 182be /home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.elf avrdude -p m1281 -c stk500v1 -P /dev/ttyUSB0 -b 115200 -F -U flash:w:/home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x000000 avrdude: Yikes! Invalid device signature. avrdude: Expected signature for ATmega1281 is 1E 97 04 avrdude: NOTE: “flash” memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file “/home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex” avrdude: input file /home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex auto detected as Intel Hex avrdude: writing flash (89274 bytes):
Writing | ################################################## | 100% 16.77s
avrdude: 89274 bytes of flash written avrdude: verifying flash memory against /home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex: avrdude: load data flash data from input file /home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex: avrdude: input file /home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex auto detected as Intel Hex avrdude: input file /home/baksiso/RIOT/examples/gnrc_networking/bin/waspmote-pro/gnrc_networking.hex contains 89274 bytes avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 18.82s
avrdude: verifying … avrdude: 89274 bytes of flash verified
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done. Thank you.
But I am assuming (blindly) that it is finding the mote and that it is flashing the application onto the board successfully.
Would really appreciate any answer!
Kind regards,
Svilen
P.S. Do you think that I will successfully be able to run the gnrc_networking application on any of the above-mentioned boards?
