i’m trying to set minBE and maxBE values.
I’m using the following function, but it does not work.
uint8_t csma_minBE = 2;
gnrc_netapi_set(iface, NETOPT_CSMA_MINBE, 0, (uint8_t *)&csma_minBE, sizeof(uint8_t));
I work with Iot-Lab M3 Nodes.
Additionally i can’t get the default minBE and maxBE values with gnrc_netapi_get() function.
Am I doing something wrong?
Thanx!
Kind regards,
Jana
This option is not implemented yet for the at86rf2xx driver. As far as I remember, the driver supports CSMA, but the CSMA parameters are hard coded.
Adding support in the at86rf2xx driver should be a pretty straightforward task. See the functions _set and _get in at86rf2xx_netdev.c, and add the corresponding functions in at86rf2xx_getset.[ch]. The data sheet for the transceiver lists a CSMA_BE register which is used for this purpose.
I can review and test if someone provides a PR for this feature.
Best regards, Joakim
Den mån 27 aug. 2018 18:21Janna Om <Janna_OM@hotmail.com> skrev:
