I’ve tried to add another 2 attributes to the “coap_endpoint_t” structure :
typedef struct { coap_method_t method; coap_endpoint_func handler; const coap_endpoint_path_t *path; const char *core_attr; const char *if_attr; // Interface attribute //const char *title;
} coap_endpoint_t;
Obviously i added the related attributes also in the coap.c file, into the handle_get_well_known_core().
Now when i call the /.well-known/core resource, the response is as follows :
</.well-known/core>;ct=40,</riot/board_GET_SAMR21>;ct=0;if=GET
And that is what i want, but now, when i perform a GET request onto the other resource /board_GET_SAMR21 the payload is EMPTY, where the right response should be a JSON string.
So, there is something that i forgot to modify, as packet length or something similar?
Thanks all as always!
