Can someone confirm that SPI is working on the samr21-xpro board?
I'm trying to make SPI work on my Autonomo board, but I haven't
succeeded yet. FYI, I'm also reorganizing the code so there are a lot
of parameters that can be of influence. I can't use the current code
because the pins and the SERCOMs are different.
It would help me to know that it works on samr21-xpro.
I can confirm that it works properly.
SPI is used to communicate with the transceiver on samr21-xpro and
communication works so SPI works, I used SPI1 also with no problem
This very same setup works perfectly with Arduino.
It is a SAMD21 on a Autonomo (very much like Arduine Zero).
It has a 16Mb "serial flash" chip on it.
I started with the code from cpu/samd21 that was developed for
the samr21-xpro board.
The "only" thing I had to change is the pins for the SPI. And with the
pins I also had to change the SERCOM, the PADs and the pin MUX.
And yes, I checked the SS pin (and all other pins) over and over.
So far I was able to get UART and I2C working. But for more than a
week now I am stuck at SPI. I use the tests/periph_spi test program.
�main(): This is RIOT! (Version: 2016.07-devel-336-g38dc1-rapper-add-sodaq-autonomo)
RIOT low-level SPI driver test
This application enables you to test a platforms SPI driver implementation.
Enter 'help' to get started
It drives me nuts. Any hint is greatly appreciated.
Do you have a logic analyzer?
No, I don't have one.
At some point I shall buy one, I guess. But that introduces new
challenges. The SPI signals are not easily accessible.
I've made good experiences with the cheap Saleae ones (I've been using
cheap remakes from ebay like [1]).
It's easy to hook them up between MCU and SPI-device, and they come with
simple but usable Linux software that can decode SPI signals.
Tremendously useful for spotting timing errors ...
Would you try to initialize an other pin as CS line? If I see it correctly you decided for PA23. Maybe just try it with PB2 (in case you don't use it for other things).
I made a local change to the format of that message, using %lx because that way I can look
up the address in the data sheet. The last two hex digits are good enough for me to see that 17 is 23.
But yeah, the GPIO_PIN() is perhaps a better idea.
I am using an Atmel ICE that connects via openocd. I can single step through the code with gdb (from
Emacs). That way I can confirm that the CS line is indeed the expected PA23.
It was staring me in the face but I didn't see it.
It was a wrong mux for the MOSI pin. I finally found by single stepping
through the Arduino code. Stupid mistake that took me almost a week
