Hi Baptiste,
as far as I remember, Tobias Guggemos http://www.mnm-team.org/~guggemos/ from LMU Munich was working on this.
Plese back check with him.
Cheers, Thomas
Hi Baptiste,
Cheers, Thomas
Hey
Tobias Heider implemented G-IKEv2 [1], which should be fairly easy to port to IKEv2 as the messages are more the less the same. It has some a dependency on gnrc_pktbuf_merge [2], which has not yet included in RIOT (hopefully he will finish this soon). If you're interested I'm pretty sure that we can share the code with you.
I had several students starting a RIOT port of ESP, but none finished it. I probably have to do it myself when time allows... I heard that Olaf Bergmann had a student who wanted to implement Diet-ESP [3], but I don't know a state of that. (obviously that would require an ESP port)
Cheers Tobias
[1] https://tools.ietf.org/html/draft-yeung-g-ikev2-13 [2] https://github.com/RIOT-OS/RIOT/pull/6487 [3] https://datatracker.ietf.org/doc/draft-mglt-ipsecme-diet-esp/
Hi Tobias, Great to hear that ESP is getting ported as well as G-IKEv2 and Diet-ESP. A good Iot µOS must provide security features
I would like to contribute to the port of ESP. Could you create a WIP merge request or a branch on a repo so I can see status of port and test.
Have you thought about using an external library?
